Heavy Air Coolers - Could they damage motherboard
8 Sep 2010
Hello guys,
I am building my gaming rig and was browsing for some coolers. I was going for the Noctua NH-D14 Dual Radiator CPU Cooler. It looks great and has had many good reviews. My problem is on one .... its WEIGHT.
On their website it is quoted to weigh around 1.2kgs when the fans are installed. I have an (expensive) Asus rampage III extreme and I am a bit worried that all this weight might (sag) damage my motherboard .
What are your opinions ?
Could anyone share his/her experience as related to this particular cooler ?
Thanks
Firstly surely the manufacturers would have tested this? Secondly lots of people use them and you don't hear often (infact I never have) of boards being warped my the weight alone.
I can understand the worry, these things are heavy but the lack of posts about it happening suggests it almost never / never happens.
Cooler manufacturers provide a backplate that helps distribute the stress on the motherboard more evenly so motherboard damage caused by a heavy cooler isn't normally an issue
AS an engineering student i can tell you that although a backplate is important an distributes the stress evenly, the stress is still confined to a small area
As long as you use the backplate you should be fine. If you are not being careful when moving your PC, I wouldn't recommend having it in place when transported though.
plenty of people use large coolers such as the noctua, megahalems and True without issues. The backplates provided are to stop any bending of the board. You'll be fine
iirc the Intel spec recommends a cooler of no more than 500g, but the Intel spec also recommends that you don't overclock, run RAM faster than JEDEC spec or do anything remotely interesting with your computer.
Heavy air coolers are fine if you install them properly.
In my experience i would go with a Prolimatech Megahalems just to confuse things, not because it better but better price/performance. Top 5 coolers all perform within 2-3c of each other so why pay £64+?
If your minds made up and you want D14 dont let the weight put you off it will be fine
Just to make it clear i was SO concerned , because i am going to use a rampage III extreme , which as you might imagine is not a cheap motherboard
  • I am building my gaming rig
£66.99 inc
Hello wenzu1989 :)
Why on earth are you considering spending £67 on a CPU cooler for a gaming rig? . . . that is a really expensive cooling solution . . . do you actually need it or?
It seems a lot of people are becoming a little "obsessed" by cooling these days . . . a cooler like this really isn't needed for most people! :cool:
Hello wenzu1989 :)
And that's why the Thermalright Silver Arrow should be considered instead which is cheaper and marginally better :p.
To answer the OP, the Noctua's weight isn't a problem at all. I've had mine for over 10 months and haven't had any issues with its weight on the two motherboards I've used it on. The SecuFirm 2 kit is one of the best available.
Are you overclocking? If not just use the standard cooler, I only ever use the standard cooler but I ensure I have a decent case, currently antec 902 and my PC is a gaming PC
