anyone else having problems getting their phone to work with kies?
Plug phone in - nothing happens
what else do i need to do ?
I Have the latest froyo and rooted it, also with the lagfix fix but my quadrant score has gone down to 1808. Anyone else get this?
It's a known problem (going by what is being said on XDA Developers) that the Quadrant score for Froyo is lower, usually around the 1800 mark.
I guess we'll have to wait and see what Samsung have cooked up for the 23rd!
Do what True_Scotsman says .
Cause i use launcher pro i just have USB debugging on in the system settings. Windows then recognises the phone properly. This is great for file transfers as i try not to use kies at all, only for flashing.
http://forum.xda-developers.com/showthread.php?t=783596Updated to 2.2 and it's running quite slow.
Anyone know how to root 2.2?
Same here not as quick as before did yiu do a factory reset after you flashed it?
Always factory reset and clear cache. Even formatting the internal SD can help.
