Serious Sam HD 1 and 2 plus Serious Sam classic versions all for £7.50 from Steam
Can also get both HD versions without the originals for £5.49. Which is what i went for.
http://store.steampowered.com/sub/4507/
Meh, if your gonna get the 2 HD versions for £5.49 you may aswell fork out the extra 2 quid for the classic versions. After all, they ARE classics.
I might get them but its 10 euros and i already have First encounter. Might try the Members Market for a GBP gift...
Why? HD is the same only better looking ain't it? So what's the point? Plus i've got at least the first one stuffed away in a box some where im sure! :D
My finger is hovering over the buy HD version, I've got the originals on DVD as well...what's the advantage of the classics, what was removed?
They've got few of quite a few of the secrets and it just seems less....fun to me. Several of the mavity things have gone as well. I still like the graphics of the originals and the new ones don't look that good. I've only played the first HD but I much prefer the original.
I don't think the remakes have local co-op either.
You sure, it says Co-op with up to 16 players for the HD version of SS1 ?
If can you, I'll be getting two copies
Didn't realise I had uninstalled it :(
Internet seems to say no split screen though.
Thanks for checking, I think we were talking across purposes though, I was thinking it didn't have co-op at all. When I co-oped with the missus we did it across a LAN, of course doing it over the net will be just the same (probably easier to setup as well!) so that shouldn't be an issue. :)
Looking at the specs, both SS1 and SS2 say that have 16 player co-op...good enough for me *ordering* :D
Just stayed playing the first encounter HD. It's not started how I remember it. I could have sworn the original game started by an oasis in the desert.
Or am I imagining this?
