I ignore the edit action. I set up my editors in the "Send To" menu instead. 'Right-click > Send To > Notepad' for example.That's fine for opening files, but it's the edit action that's the issue.
i use software called default program editor which is something that should have been included in windows 7 to begin with.
Microsoft products are like nazi on the file associations, install windows media player and you can't get any other software to open .wmv, i didn't try editing the registry, i just uninstalled wmp.
ccleaner preinstalled
That would be annoying.
Some form of UAC whitelist - so much hassle running some programs - especially legacy ones.
Creating a whitelist mechanism would undermine the whole point of UAC. Either through exploits, social engineering or being a complete pleb something nasty will jump on board, and simply whitelist anything it wants.
It's the same way outbound filtering is useless against malware. If it is on your computer in the first place it will simply allow itself through the firewall.
We already have a kind of UAC whitelist which only Microsoft can use.
More importantly though, introducing a white list for UAC will contradict the very reason MS implemented UAC in the first place; to stop developers modifying directories and registry entries they really shouldn't need to after they've been installed. Instead of re-writing the code it would be cheaper to tell their customers to just add their software to the white list and we'd be back to square one.
A better Windows compatability Mode. Ie a free virtual pc version of windows 95/98/2000/xp/etc... which has full DX aceess to hardware and runs when compatability is set in the compatability tab, instead of the current way it does it which frankly doesn't work.
What?
