- 16 Jan 2003
- Nottingham
So, looks like Barts can be used on the same boards as Cypress.
HD 6000 Series on 22 October 2010. The launch was initially slated for 12 October but was pushed back a week to the 19th prior to this. Fudzilla has also confirmed that the Radeon HD 6000 Series will launch on the 22nd.
by some Chinese websites, the Radeon HD 6870 will only be a little faster than an overclocked Radeon HD 5850. There sure is some name-play going on here; the x800 naming convention has traditionally been given to high-end single GPU cards but it seems that the Radeon HD 6870 and HD 6850 will be replacements for the current HD 5700 Series instead.300 watt for the 6970, not that efficient after all, unless of course it blows the 480 away, which looks doubtful.
I wonder about the Juniper though. The rumour is that they are re-branding it, but perhaps it's just that the Juniper refesh is later than the others and will come Q1 2011 instead. Or maybe they do plan to re-brand it at a lower price point (to compete with the 450), but I'm struggling to see how that makes any sense for them.
if its faster then 480 it does not meed it needs more power slide showing estimated performance not power consumption.
That's exactly what I meant. If they are lowing the price point it makes much more sense to use a smaller, cheaper chip. That would also mean they would need less wafers to produce the chips, freeing up more supply of higher-end chips. OTOH they were pretty small anyway and maybe they just have an enormous stockpile of Juniper chips? Or maybe they will refresh Juniper next year.Given that's it's (5770) already faster then the GTS450 AMD don't really need to do anything here. However it would make sense for them to use Northern Islands technology to make a chip that’s smaller then the 5770 but gives the same performance which would increase margins in a segment which has rapidly reducing returns.
As noted elsewhere the slides apparently date from before the 450s official release, so having that incorrect actually adds credibility IMO. Missing an s from Northern Islands is pretty minor.Northern ISLAND (s missing) and GTX450? (it's always been GTS450?). Smells like a sloppy fake to me
