- 24 Feb 2004
- Leeds/Cyprus
Rib Eye, Sirloin, T Bone, Rump, Fillet... all steak is good.
I'd advise against Fillet. Anything under medium is difficult to cook at home as you simply don't have the temperatures needed seal and cook the outside whilst heating the inside without cooking it. It's just too thick. Fillet is a cut best enjoyed as a treat, cooked in a proper kitchen.
Not saying its impossible, but if you dont cook yourself steak regularly.. avoid disappointment and get something with less mass. Fillet is a tricky one to pull off.
That's exactly what the cooking method I linked to (2 posts above yours) is supposed to resolve! If you leave the steak in the water bath for about an hour it'll get cooked through no matter how thick it is! Then you can just sear it on the outside and hey, presto! Deliciousness!
Yeah, they're like the Consolevania of cooking aren't they? And the graphics remind me of Zero Punctuation a bit.lol, thats got a very, top gear style comedy about it....
I tried it again last night, this time I didn't drop the thermometer in the pot so it was all good! Worked perfectly!
Left it for 2 hours, think it was excessive, it was nice and pink on the inside but not very rare like I usually have it. One small tip: use A LOT OF WATER in your pot, to make sure the steak floats! Otherwise it'll be touching the bottom of the pot, which will be hotter than the actual water bath, and get very gently grilled. (unless you've got an induction stove, of course, where the heat is generated in the pot rather than being conducted through the pot, so it doesn't make a difference)
