- 26 Mar 2007
Would anyone care to advise me about the following selection of equipment?
I will be predominantly cleaning a Black 2007 Accord with almost identical paint to the one posted above, and a 1993 Clio Williams.
I have a fair amount cleaning and polishing products already but am lacking in a range of things that will enable me to remove light scratches and swirls.
Dodo Juice - Supernatural Buffing Towel DOD159 £5.91 £5.91
Dodo Juice - Blue Velvet DJBV250 £27.66 £27.66
Sonus Glyde Detailing Clay Lubricant SON-300 £5.91 £5.91
CleanYourCar - Fine PolyClay (240g) CLEI9 £11.02 £11.02
3M 3434 Masking Tape 3M3434 £2.38 £4.77
Dodo Juice - Spin Doctor rotary DODJ17 £80.81 £80.81
Sonus SFX-2 Paint Polishing Pad SFX-2FP £7.62 £7.62
Sonus SFX-4 Final Gloss Seal and Protect Pad SON-SFX-4FP £7.62 £7.62
Sonus SFX-3 Final Finish Polishing Pad SFX-3FP £7.62 £7.62
Sonus SFX-1 - Swirl and Scrtach Remover Pad SFX-1FP £7.62 £7.62
5" Dual Action Flexi-Plate SON-DASFP-5 £11.02 £11.02
Sonus SFX-2 Enhance Polish SON-420-8 £7.62 £7.62
Sonus SFX-3 Final Finish Polish SON-430-8 £7.62 £7.62
Sonus SFX-1 Restore Polish
I've stuck to a group of products that I've read up on and believe to work well together, and thus should provide the range of finishes that I will be looking for.
Does that lot seem resonable? Does anyone prefer another product over the ones I have listed that do a similar or better job?
Thanks
Thanks
and is getting rather swirly. Also there's a fair few stone chips
