Wow, will have to tell my dad about this, MPG going from in the 30s to 50MPG is amazing!
Wow, way to misquote me and add absolutely nothing to the debate. I'm amazed at your knowledge of fuels and the incisiveness in which you destroyed my position.
[TW]Fox;17646829 said:
You are going way, way, too deeply into this.
Different fuels will obviously affect the way a car runs but you are basically suggesting a normal diesel car will not run properly on normal Tesco diesel fuel. It is this which I take issue with.
No, you're now agreeing with me without trying to say it out loud. Originally you were calling me stupid and LOLOL-ing at my suggestion that a car would run differently (not badly, DIFFERENTLY) on Tesco diesel compared to BP and Shell.
All I've ever said is that (1) Tesco diesel runs, but it runs smokier and (2) it returns less MPG (3-5mpg if you actually read what I wrote). This is easily verifiable even by reading the EN spec for diesel. Even if we ignore 'above spec' fuels (VPower, Ultimate) the spec itself provides a massive leeway for fuel quality ("up to" x parts per million water, "at least" x cetane etc).
All I've been saying, all along, is that Tesco is BOG STANDARD. I never, ever said SUB standard - you put those words in my mouth for me and I've been refuting it ever since. I then said that given Tesco is clearly 'bog standard' I have indeed found (as one would expect) that an 'ABOVE standard' fuel works better, doesn't smoke as badly and returns better economy.
Looking at the allowed calorific density within spec, this is easily and quickly demonstrable to even a primary school child. For example even just within 'bog standard' EN 590 spec fuel you can by law add between 5% and 7% biodiesel. Ignoring differences in biofuel feedstock etc (let's say they're identical for now), 5% to 7% biodiesel gives us almost 50% more biodiesel in Mix B than in Mix A. BOTH are EN spec.
Biodiesel is LOWER density, LOWER calorific value but HIGHER cetane than 'normal' fossil fuel diesel. As such more biodiesel gives LESS MPG and (depending on feedstock) more smoke and more water content (still in EN spec).
Such a fuel will, surprise surprise, smoke more and get less MPG. Something you've laughed at me for asserting throughout this thread.
If we were arguing whether better diesel means you get 2-3mpg more or smoother response then fair enough. But you are basically one step away from claiming Tesco makes your Berlingo HDI undriveable. I mean seriously, you tell us that filling up with Tesco fuel results in a plume of smoke and more than 20% less fuel economy. Thats not just a less suited fuel, that sounds like a downright faulty fuel to me. If you are right, Tesco should be taken to task for selling unsuitable fuel.
I suspect, however, that you are not right. You've correctly identified that certain characterstics in fuels have certain effects, multiplied this 10 fold, and are now convinced that using Tesco fuel in a Berlingo makes it smoke like an HST on full takeoff.
Tesco diesel is entirely suitable for normal diesel cars.
It's not BP and Shell I need to CC into this debate, it's Trading Standards you need to CC if you beleive your claims to be true.
Remember - you are not claiming that BP and Shell fuel is a bit better, you are claiming that Tesco is dangerously poor!
There you go with the misquoting and the straw men. I never said Tesco was substandard, I said it smoked more and had less power (and hence less MPG). I said compared to 'proper' fuels (BP, Shell) it ran **** poor. YOU have made assertions on my behalf which extended the scope of my original statement.
As I've said throughout, I can PROVE my position (and have done so to an extent, even the EN spec and biodiesel explanation above achieves this). You on the other hand have misconstrued me, twisted my words, and tried to make me look stupid.
Now, it seems you're rewording my argument and presenting it as your own. If you have simply misunderstood me, fair play. If you re-read the thread you'll see I've been saying EXACTLY what you've just said in that last post, just in different words. I even provided examples to back myself up. Meanwhile you were comparing petrols to diesel and saying I was a lunatic (basically).
As it transpires, I wasn't wrong at all. I can literally write you a referenced essay to more deeply explain my point but that won't be necessary I'm sure. I'm simply saying that you've taken half of the wrong end of the stick, and made a meal of it. I trust now, you can at least agree that I've clarified my position, explained it well, and that I was in fact correct in what I was saying.
