Cost will be the major factor hear, most goose jackets range from 4-800 quid.
But this websiteseems cheap......
This is the one I have http://www.gooseparkas.biz/canada-goose-expedition-parka-4565m-p-4.html
KaHn
£500 on a winter coat? Are you relocating to the north pole?
Personally I think that with a skin base layer, fleece with windstopper and a fully waterproof outer layer, you will warmer dryer and have spent a lot less than a canada goose jacket.
I was going to go for the McMurdo or the Prism optimum until i went into a couple of stores and asked about coats in general. I was told that for english weather where it rains a fair bit, down filled coats arent the way to go because it will bunch up like a tennis ball when wet.
I have to reiterate this, are you planning on an Antarctic expedition ? or just wearing it to the car for 30s every morning?
https://www.adventurepeaks.com/acatalog/Rab_Summit_Batura_Jacket.html
£300+ though
If it was mr though id go for this with a fleece.
Get a little bored with itBuy once. Buy well.
? Considering a coat is only meant to keep you warm anyway. A hoody can keep me warm during the winter ^^ unless your going to the poles!Atleast in Britian, you won't need Canada Goose.
The traditional multi-layered approach is something I've tried in the past, but don't really like if I'm honest. Wearing a fleece under a Gore-Tex shell always makes me feel like the Stay-Puft Man from Ghostbusters![]()
But have you ever tried on the ice, gotham or mcmurdo coats? I tried on a mcmurdo and felt like mr soft(or as you say the marshmallow man)
Its 2kg!
