The more I look at this the more complicated it gets ! As far as I can tell the procedure is as follows...
1) undo OC
2) Unplug old HDD
3) Change storage to AHCI in BIOS
4) Plug in new Vertex 2e 120Gb to Intel sata ports (blue)
5) Install W7 64 to Vertex
6) Install Intel RST drivers (not sure how to do this)
7) Open RST in system tray and check that disk data cache is ennabled
8) Run WEI
9) Disable drive indexing and any defrags
10) Check that write back cache is enabled in device manager.
11) Profit !
Then there's the problem of the SMART error. If so, I'll need to Flash the BIOS. Which I have no idea how to do.
Can anyone tell me
a) If I've got the procedure above right ?
b) How install Intel RST drivers ?
b) How do you flash the Gigabyte mainboard ?
Thanks in advance
1) undo OC
2) Unplug old HDD
8) Run WEI
11) Profit !
Can anyone tell me
Thanks in advance
