upgrading hdd on 4gb black 360
You can buy Western Digital BEVS or some such and then flash them to work. The method is probably frowned upon here, but if you google it then there will be guides telling you which models work and how to do it.
Or use Alpherahs method and it will work right away.
has any one tried this?
Yes, it works. Also, MS will not ban you for using either an official or unofficial drive. Sure, it's technically against the ToU but they don't ban for it.
cool, I prefer the look of the 4GB xbox :-)
and its £149 with 2 games + a £20 voucher... may pick one up l8a
I also have a WD250bevs drive
I do hope you're right! From what I have been reading, although people have been using hacked WD drives for quite a while now, there is still a slim chance that the consoles could be banned from Live in a future update as the drives have an identical serial number after the 'operation'.
Of course there is always a chance, but I honestly can't see MS doing it. People have been using these hacked drives for a few years now and there have been loads of updates, I would have though that MS would have done it by now if they were going to.
