done some cablemanagement today. bit of OCD if you ask me.
camera is a poopy 5mpx so dosent do justice.
also, im thinking of getting black sleeves ofr all cables, they look shoddy in case.
also, i hate blue mobos :/ looks so peasanty in a red themed and lighted case :/ especially with blatent red ram.
There's no such thing as OCD when it comes to good cable management, having the best possible cable management is essential to have a nice looking rig imo.
You should look into buying pre-braided extensions for your 24-pin and 8-pin ATX cables, or you could just buy normal extensions and sleeve them yourself, it will give your rig a much better look.
And yes, you're right about the whole blue mobo thing, I used to have the UD5 too (pretty much the same as your UD7 except no WC block on the IOH), but when I got my Dominator GT RAM and the internals of my case coated red there was absolutely no way in hell I was putting the UD5 back into my case!!!
I ended up getting the RIIE to replace my UD5, but I can no longer acheive the same 4.4GHz clocks that I could get out of my 920 D0 and UD5, the highest stable clock I've got on the RIIE is 4.2GHz.
Should have just held off buying the new board for a couple months and waited for the RIIIE instead, or a Classified, but I am impatient when it comes to buying components.
The RIIIE would look very nice instead of that UD7 mate.
