Same could be said about a customer ordering something he's not supposed to.
There's always 2 sides.
Except the customer is always right
how did you buy a 95w edition by itself anyway? You can only obtain the 95w edition with a system or motherboard bundle.
What do you use to measure your CPU temp?
Did not work out as planned. Was told today that all current stock of the 95w 1055T's are labelled wrong and in fact they are all 125w versions. Find that hard to believe but it could be possible. Anyway went for a 1090T black Edition as that is on special this week for £199 and with the refund for Saturday delivery and free delivery on the 1090T it only works out about £5 more then the 1055T 95w, so I guess not too bad. Should be easier to OC with the unlocked multiplier.
That's not bad mate, ye the 1090T will oc better![]()
nope
nope
just easier thats all, they are the same just unlocked multi.
Also I don't see how OCUK can confused the 95W/125W 1055's, one is in a retail box and the other isn't.
How so?
1055t is locked and the 1090t ain't.. thats why.
Hmm did not think of that. The CPU I was sent is retail as it has a stock heat-sink and fan. The OPN is the 125w part and the Overclockers UK barcode (CP-273-AM) is for the 95w part. I wonder if anyone else got the wrong CPU and did not notice LOL.
Would probably be just my luck. I bought mine as part of an overclocked bundle, so wasn't retail.
Is there any way to tell without having to physically look at the cpu?
the 1055t is locked ?
Open Core temp to check the VID.
The 95W will be 1.275 (I think) or less.
Might try that, but as it was part of an overclocked bundle I think the VID was upped quite a lot. (The chip ran very very hot).
