I am planning on installing a new quad LNB for the new Panasonic Plasma that is on the way from JL. Having never done this before I thought I would ask for some advice please.
This is my current Sky dish that supplies a feed to my Sky box (this will remain in place for the old TV).
I believe it is a 43cm Zone 1 minidish as installed by Sky, but cannot be sure. It clearly only has a single LNB.
I am planning on purchasing a quad LNB (from here)
I understand that this will be a simple, remove and replace (possibly held by a single screw on the underside).
What connector connects the LNB to the cable I shall be installing?
The cable I have planned is this
Also what connector will connect the coaxial cable to the TV freesat? Will it be the same as the connector for the cable here?
Also do I need a crimpler tool for the connectors to go on to the coaxial cable.
Thanks
Thanks
