- 18 May 2010
- London
I can confirm I have every single setting turned on in DX 11!
I have Antialising set to AAA and AF set to 16x
Physx is off, but Depth of field and tesselation are on!
This game is running like a dream! Runs better than Crysis warhead!
I am not having you on, game is not demanding at all!
The 2gb vram must be playing its part!
Just to confirm settings:
Res: 1920x1200
Quality: Very High
Dx version: 11 (Depth of Feild = on, Tesselation = on)
Antialising: AAA
AF: 16x
Ok after a bit more of a play through, I can see that the frame rate is higher and lower in certain areas, even if its those areas have similar environments.
I wacked the Antialising to MSAA and it started lagging a bit! Only a bit, generally when you quickly pan around looking, it was a little bit stuttery. In all honesty, you could still play the game with all the settings turned on, and the stutter wouldnt be a deal braker.
However, as I was perfectly happy before I tried the MSAA I went back to AAA, just tto help the frame rate. Iv also gone back to AFx4 as was still a little bit jerky.
There isnt any difference between 4x and 16x AF.
The MSAA look good. But the game still looks great using AAA, and Iv read thats what you should use if you have an ATI card, so thats what il keep.
But for a single card, and 2nd generation cpu I think my Pc is doing just fine.
So just to confirm settings:
Res: 1920x1200
Quality: Very High
Antialising: AAA
AF: 4x
Hmm maybe Il have a play with turning depth of field off (as you guys say it is a fps killer whilst offering little) and turn MSAA on...
Max was 116 fps from memory.
