finisihing my build (the nooby way)
17 Sep 2010
ireland
nearly done just need to check some things.
me Qty Price Line Total
Gigabyte GA-P55A-UD4 Intel P55 (Socket 1156) DDR3 Motherboard £149.99
(£127.65) £149.99
(£127.65)
Gigabyte GeForce GTX 460 OC 1024MB GDDR5 PCI-Express Graphics Card with HAWX2 PC-Game £144.98
(£123.39) £144.98
(£123.39)
Intel Core i5 760 2.80GHz (Lynnfield) (Socket LGA1156) - Retail £140.99
(£119.99) £140.99
(£119.99)
XFX 850W Black Edition Modular Power Supply £124.98
(£106.37) £124.98
(£106.37)
Microsoft Windows 7 Home Premium 64-Bit - OEM (GFC-00599) £82.99
(£70.63) £82.99
(£70.63)
Coolermaster CM-690 II Advanced Dominator Case - Black £76.99
(£65.52) £76.99
(£65.52)
Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX4GX3M2A1600C9) £65.99
(£56.16) £65.99
(£56.16)
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) £41.11
(£34.99) £41.11
(£34.99)
Titan Fenrir Evo CPU Cooler (Socket LGA775/LGA1156/LGA1366/AMD K8/AM2/AM2+/AM3) £35.99
(£30.63) £35.99
(£30.63)
Sony Optiarc DRU-870S 24x DVD±RW SATA ReWriter (Black) - Retail £18.99
(£16.16) £18.99
(£16.16)
bad cable management i know but i did all professional looking then had to redo all over again :(
i know its blurry but it says ac97 and its attached to hd audio but has no where to go help?
?? Connect it to the either the A97 or HD audio connector to the F_AUDIO header.
What mobo is it?
Might be a good idea to post your spec in opening post.
i have a hd audio cable plugged into f_audio and attached to that cable is another named a97?
You only have to connect either AC97 or HD Audio, not both. I believe HD audio is the better of the two. But since certain older mobos don't support HD audio the connector gives you the option of both.
beside the front panel connectors there is two usb ports which port shall i use usb2 or charge? see pic
charge?
Just put the front USB header(s) into any USB2 marked port. If you are not sure which port it will be marked on the board and in the manual. The blue one it is in now will be fine.
I think this is what you are getting at.
right stupid question number 2 my xfx psu has nowhere to screw it in to my case will it stay without it?
I wouldn't recommend not screwing it in.
The PSU will have screw holes in the back and these need to line up with the screw holes in the case. You may need to move it around a bit to line them up, or flip the PSU the other way up.
