 - 28 Mar 2007
 - Lincoln, UK
In Safari doing CMD+<number> will open sites from the bookmark bar, e.g. CMD+1 will open the first site listed. +2 the second etc.
You can remove/reorder (some) icons from the menu bar by clicking on them with command held down and dragging them.
Dragging a file or folder into an open/save dialog box will change the location to that of the file/folder.
