Is there any point in buying a card that expensive anymore?
i play a very hardware intensive version of wow (many mods and in ultra mode).
even with a 4.3ghz i7 cpu, i need MORE
Was is sent from some guy called 'Ravman'? I think I got the same email.
Good price though
Is there any point in buying a card that expensive anymore? Doesn't the 6870/5870 run pretty much everything maxed out up to 2560x1600?
I doubt anything intensive like Metro 2033 is gonna be out until...well, Metro 2034. That'll probably use the same engine anyway.
Only thing I'd consider spending a bit more on is The Witcher 2 because that looks incredible graphics wise.
I got that email too, 399 for gtx580, preorder. However if you super depserate there is a way to get your grubby hands on a 580 right now!
The same shop also sells ready made systems with 580s in them already, and they are all ready to ship for £999, if you just want the card, just strip the pc when you get it, sell of the parts, and keep the 580.
I'm not so sure even the most extravagant, clinically insane Nvidia fanboy would go to such extremes.
