Mainly because the camshaft will continue to rotate from momentum, bit like a flywheel. Its turning at 800rpm at idle so the chances are it will not stop dead unless something jams it, and anyway the bottom end of the engine will still be moving up and down as it gets the drive fed back through the gearbox.
I had an escort 1.6 cvh that snapped its belt and caused no damage, by chance i was going at such a slow speed that the valves and pistons didn't meet. Still took off the head to check that there was no piston damage.
