Do you leave you pc on 24/7?
I leave my current system on hibernate when I'm not using it. I think after an hour of being idle it switches to standby the after that it will hibernate shutting everything down but leaving where i left off stored in the RAM.
My HTPC is on 24/7, until this weekend my main machine was on 24/7 because it was the music and download server. After this weekend the HTPC becomes the music and download server as well so main machine can get switched off when I'm not using it.
Need your input on this folks...
Once you've put your beloved rig together and it is operating as it should without any stability issue, do you leave it on 24/7 or do you swith it on and off only when required and what are the pros & con:confused:
I just sleep mine at night. I shut it down for the night when there are some updates or something that needs a reboot.
PC off at night, to loud to sleep through, and wasting energy.
Never turn the Macbook off though due to the instant restore from sleep and low battery consumption.
I use mine for about 10 to15hrs a day, if l go out its set to use hibernate, restarts in no time at all, very handy...;)
due to now having family and lack of money for last few years its only turned on when needed. to try and save electric.
BUT i have been through 4 psus in the last few years when it was always running bits never blew
I turn mine off as its a Skulltrail and just sucks electricity so easier to wait for a bit in the morning for it to start up again.
Regards Sam
I always turn my PC off when not in use, I see no point in leaving it on if I'm not using it. I do find it strange that peeps here leave there rig running when they don't use it?:confused:
Do you leave your car running when you go in your house or go to bed..........................erm No you don't.
TC.
TC.
Let's not compare elephants & mice:D
If you live your pc on, lets say...It is your electricity you're waisting...But if you leave your car running on the drive way, well, you may make some thief very happy indeed:D:D
