Early ones are knocking on 20 years old.
Chassis wise pretty much identical to the Supra with a few sutble differences.
Three (Well, 4) engine available. Silky smooth V8 was available for the "upmarket" cars which had a spec list that makes some moderrn upmarket cars seem basic. Then you've got cars like mine, plenty of performance from a 2.5 twin turboed Yamaha tuned engine. Rumours of a 170MPH top speed, 0-60 well into the 6 sec mark and absoultely loads of aftermarket support, the engine was later replaced by a single turbo unti with VVTI. Then you've got the 3.0 cars with the same engine available in the NA Supra and GS300. Unloved really, they don't have the toys of the V8 or the power of the Turbo cars, can be picked up silly cheap.
Loads of car for the money when you consider that you can pick them up all day long for £1,000. That doesn't mean you'll get a good one, but from experinece a bad Soarer drives a lot better than many good examples of other £1000 cars. I paid around that for mine and given the chance, I'd have saved up my pennies for a lot longer and bought a properly sorted one (Like the Purple Manual on Pistonheads
), not to say that mine has been bad. The only repair I've
had to do was a replacement radiatior, but there is a long list of bits I'd really like to get sorted before I was truly happy
The Value for money thing means even more when you consider a Supra TT automatic of a similar age will command £6000+ for one worth owning, while a good Soarer, a car not much worse and arugbly better in some aspects (Have you seen a Supra's interior!?
), can be had all day long for £2,500.
I love em. They're old, but so what? Even if I do get rid of mine someday, it wouldn't be long until I bought another
