for a 470... i know this is a cheap psu but i dont have the money for a good one at the mo.. i have a [email protected] arctic freezer pro and 1 hdd
Yeap thats dual rails.
both provide 24A each.
Incorrect, you can't just add up the rails and assume that's the maximum output, it doesn't work like that.
@OP, you need to replace the PSU as that looks like a generic.
Wrong.
Yes you can his maximum output is 24 on Rail1 and 24 on Rail2.
To OP. This guy has no clue your psu WILL BE FINE provided you use both RAILS.
any more inputs as this is going to get complicated as i can see?
my psu has a single 6pin adaptor the 470 needs two i was going to use a adaptor to get another 6pin..
oh god :S what would happen if i just chanced my luck plugged the 6 pin in used the adaptor on 2 spare 4 pin plugs and pluged them into the 470 - what would happen if i got the same rail as the 6pin? would it just not boot (then i would just try all my 4 pins til i got 1 that worked)
Easy way to find out is to locate where the cables leave the PSU. Find which cable leads out of the PSU for the 6pin and find 12V cables and see if they are the same. There should be a distinct difference as they both exit the psu from different points.
Most 12v multi-rail units can't output what they add up to.
For most computer user's the difference between multi-rail and single-rail is meaningless, but 3 x 15a @ 12v is rather crappy, I'd go with the single 45a rail in that scenario.
Before anyone comes in and say's " most psu's are single rail anyway ";
Multi-rail designs ( other than those 1000watt or higher ) are fed from a single 12v source that is divided useing OCP ( Over Current Protection circuits ).
In most cases those protections are set higher than the stated rating, example;
750 watt Antec TPN ( currently powering my system ) has 4 x 25a @ 12v on the label ( 62a combined ), by going to the Antec site you will find that the OCP is actually set for 40a per rail ( most unit's are not set this much higher ).
I've also run the same system with a
3 x 18a unit ( Corsair 620HX/ max load 50a, considered to be single rail because of a high or non existing OCP setting )
4 x 20a unit ( TPN550/ max load 45a )
4 x 18a unit ( Odin GT550/ max load 41a )
2 x 17a unit ( Antec EA500S max load 34a, again considered as a single rail unit due to high OCP setting )
You'll notice that the EA 500 goes against what I said above, by being able to ouput the sum of it's rails, it's the one exception that I know of. It's the earlier Seasonic built design, the new revision is Delta built with 2 x 22a / max load 34a ( OCP set at 25a )
Overall, if you're not building a multi gpu super gamer it is more important to worry about quality than number of rails.
