Treebiter I added you to the whitelist yesterday
V4nger What was the post number where you asked to be added I can't find it ?
Can you post your MC player name.
Look at post number 2 on this thread if your name is not shown on the list then please repost.
LAVA & WOOD DO NOT MIX
If you value your work then do not use lava and wood if a creeper explodes next to your house up in flames it will go. Same thing also happens when we have a update the lava fix mod stops working for a while so up in flames you work goes.
It also makes the server look messy with burnt down buildings I can remove the use of lava if it keeps happening.
Monsters on or off I am not sure.
