getting the constant sync symbol with this LeeDroid ROM. Has to be said, I'm now on the A2SD ROM and it's still not making me horny
Ah it's best not to remove those as those that start HTC* as those are core services required by the htc framework.
Maybe this is why![]()
I had a look at LeeDroid and noticed the A2SD+ add-on needs an EXT3 partition, I think that's a bit technical for me right now, so should I go for the LeeDroid without the A2SD+ add-on?
edit: oops! I was looking at the old version of LeeDroid (1.9)
leedroid still really needs the a2sd+ cache, i find it chuggs and crashes a lot more without it.
you can do it in rommanager, just backup the sd card on to your pc, then create the partition in rommanager (i did 500mb) then install the rom and more your sdcard stuff across again.
it is pretty simple/
Titanium only stores backups on the SD card
Before flashing just do a full wipe and factory reset from recovery and then flash the new ROM, reboot fully then flash any addons and then start restoring user apps+data one by one using Titanium. Running a batch restore can cause problems sometimes.
