Id say sli would be a bit iffy with this cooler, dont think it would be possible on my own board, even though the space between pcie slots is pretty good.
Asus p6t dlx v2
Nice setup
but what is that strap thing around your PSU?Please remember that any mention of competitors, hinting at competitors or offering to provide details of competitors will result in an account suspension. The full rules can be found under the 'Terms and Rules' link in the bottom right corner of your screen. Just don't mention competitors in any way, shape or form and you'll be OK.
Asus p6t dlx v2
but what is that strap thing around your PSU?Nice setupbut what is that strap thing around your PSU?
Looks like the same case as mine, It is to hold the psu in place. The whole case is of toolless design.![]()
I was also considering SLI in the future, when the 470's come down in price a fair bit. What stopped me though is the fact im not experienced in w\c, and can't possibly envisage how i could have two overclocked cards with stock fans running at the same time on a high setting. One is bad enough, two would be completely ridiculous.
So, when the 570's come out, and the price has dropped down a bit, I might consider that path.
Of course, the gelid is the other option. please post findings if you get one.
Im running mine at a modest 750mhz oc, heat isnt much of a problem tbh, i have a 120mm fan mounted behind the cards, idles of 31-30, load temps in game of 77c, auto fan so still pretty quiet.I was also considering SLI in the future, when the 470's come down in price a fair bit. What stopped me though is the fact im not experienced in w\c, and can't possibly envisage how i could have two overclocked cards with stock fans running at the same time on a high setting. One is bad enough, two would be completely ridiculous.
Yep, its a feature on Lian Li cases, no screws required to hold the psu in place, aside from the mobo mounting thumbscrews, the only other screws used in this case are for my fan controller, (zalman), a Lian Li controller just clips into place, and the case fans, though i may mount those with rubber bolts.Nice setupbut what is that strap thing around your PSU?
I'm running a couple of GTX 480s with threse on and SLi works perfectly. I've even got a single slot 9800GT in between them as a PhysX card. Motherboard is an Asus Rampage Extreme III.
Rolypolyman,
Nice temp drops ! Can you try running with fans at lower speed setting and let us know your results?
I phoned Overclockers about this, and they said yes it does.
