Just to clarify you can flash it even though the bios version is the same, as i done it earlier.
How did you remove the check though? So i can do it to the other 1.28 bios if i decide i dont like this bios?
Its in the platform.ini file.
You can just remove the BAP31.128_SLIC_QUIET.fd (this is the bios file) from the folder and replace it with another fd file like the official acer bios and then just run the flasher and it will work fine. (It doesnt have to be named anything special either. Just have .fd on the end)
