MOT tomorrow, car is dirty :-\
Refusing is different to a fail. But i didnt look at where he was from. Is the test any different in NI?
Quite different. As I understand it Britain allows independent mechanics to assess the car for MOT - doing the appropriate work to get it to 'road worthy' status. That testing is 'randomly' monitored by a government body. Correct me if I'm wrong on that.
In NI, independent mechanics carry out work and the car is then tested in a government run facility - the MOT centre. As the work on the car is completely unrelated to the person testing it - they're not overly concerned about getting their fingers dirty to see if a brake pipe is clean, for example.
As for a car 'having' to be washed underneath or otherwise for an NI MOT, that's not true.
LOL
Make sure you dust the interior as well. I also heard that if you have a crease in your leather it's an insta-fail.
How would you expect the underside of your car NOT to be dirty?
Sometimes I really do despair...
OP - Your car will not fail its MOT for being dirty. :rolleyes::)
MrLOL said:
got any actual source for this ??
I've found lots of internet heresay, but no actual proof ?
Sigh. Totally with teaboy on this. Why post opinions and take the **** about something its blatantly obvious you know nothing about? You just make yourself look stupid.
Your vehicle should be road worthy with all the equipment working correctly, therefore it is advisable to have your vehicle checked by a mechanic before you bring it for a test. You must also ensure that the exterior/interior and underparts of the vehicle are clean, otherwise the examiner may refuse to test it.
http://www.nidirect.gov.uk/index/in...vehicle/mot/how-do-i-prepare-for-the-test.htm
Bet you all feel daft now, eh?
Refusal might be technically different to a fail but it amounts to the same thing - you don't leave the test centre with a valid MOT!
No because most of us are not in NI
But the OP is, and his question relates to NI. He cares not what the MOT policy in England is, as he is not MOT testing a car in England.
However, you can also fail an MOT or have an MOT test refused for having a dirty car in this country, as well. Listed amongst the reasons for refusing an English MOT test is:
b. the vehicle or any part or equipment on the vehicle is so dirty that examination is unreasonably difficult:
There are also fail points where things like lights etc etc are so dirty that operation is impaired.
So, my point stands. LOL @ all the people who took the mick at the idea you might fail an MOT or have a test refused for having a dirty car.
Not really.
As it happens, the way I worded my post gives me a get out clause anyway! So... it won't FAIL for being dirty but it just might be refused test. :p
Nevertheless, I didn't use Google or pull out the rulebooks before I made my post. It was a reasonable assumption I made and fair enough - It seems I may have been proven wrong. :cool:
Not going to argue but if it was that dirty it would get noticed on the pre checks and would not make it into the mot bay lol.
"the vehicle or any part or equipment on the vehicle is so dirty that examination is unreasonably difficult"
"The vehicle is so dirty that examination is unreasonably difficult"
I'm assuming that this means the car is absolutely caked in mud and the test cannot be undertaken.
A) this is different to failing an MOT
B) the underside of a car with a bit of road dirt and salt is NOT "so dirty that the examination is unreasonably difficult".
Also, how clean does the car need to be in N.I.? I assume it's the same as England in that by "clean" they mean "not so dirty that the test cannot go ahead.
I.e. they'd refuse to do it if there was mud all over, but not if you had some crumbs on the floor.
I worked in an MOT testing station for 5 years on and off and we refused to test quite a few vehicles that were caked in mud underneath.
Did you refuse any for having a bit of road grime on or some crumbs on the carpet?
Nothing worse than having to remove half a field before you can see what you want lol.
No. But with that said, we were not in NI so it isn't hugely relevant to the OP.
Perhaps, but i assume that the N.I. rules are as reasonable as ours, hence i can understand them refusing to do a test if it has half a field, but not if it has some dirt on it?
Or are the Irish very keen on cleanliness and insist on every component to be gleaming?
