Is there a way to partition the SD with Clockwork? I can't see anywhere to do it?
Who's that with?
I had the same problem and the guy was a right arse and wouldn't refund me, it was the company Khaan suggested in the Android rooting guide.
Made a dispute through paypal in the end and got my money back.
rom manager does it via scripting, uses clockword to boot into recovery. amonra does it all within recovery.
No need for ADB eitherJust hold vol down+power hen turning on and choose recovery using the volume and power keys after 10 seconds.
Ok, seen as you guys use it ill change. Got the link AmonRA, downloaded recovery-RA-desire-v2.0.0.img...
Now what?
This is the part where you do require adb but be sure to be S-OFF.
Volume down + power on with usb connected after putting the img file in the root of the tools folder in the android sdk folder.
Open a command promt at the tools folder and type
fastboot flash recovery recovery-RA-desire-v2.0.0.img
This will flash the recovery image while the phone is in fastboot mode. Should take no time at all.
Back in then wipe dalvik cache + wipe all user data then flash!
Cool, i'm in and partitioning my SD. Do I now need to reboot into Android and copy the ROM over, then back into AmonRA to flash?
After flashing it has rebooted to the AmonRA recovery and it says Formatting CACHE:...
Should I leave it?
I'm happy with my flashing (oh er!) for today. But if I decide to go for a different ROM do I need to wipe each time? I guess you guys who swap ROMs all the time wont be happy reinstalling all your apps/settings each time?
