I will share my Tips and Tricks Including installing a 3G modem and a 2nd HDD and my modded quiet bios.
Alright I've just found this thread and see a lot of people have this laptop now.
I'm dragonuk from notebookreview.
CPU OVERCLOCK
First thing is the cpu overclock does seem to give a great boost and not effect battery life or have any side effects at all. So most people should use it fine
When using CPU-Z my cpu sometimes shows a x7.5 or x8 multiplier. Don't know why this is as the cpu is only meant to have a x7 multiplier. Anyone else seen this ?
If you want it to run everytime windows starts, open task scheduler and click Create Task. Set it to trigger on startup and on workstation unlock . That means when you return from sleep or power on your laptop it will automatically run the cpu overclock.
GPU INFO
Now the GPU. The GPU does seem to run really hot when playing games 80C etc. One problem here is the fan on the laptop is set to come on at different speeds depending on the CPU Temp. So if the cpu temp is really low and the gpu is really high the fan won't turn on. There is not much you can do here except modify the cooling in the laptop internally.
INSTALLING A 2ND HDD (SSD)
Some people mentioned on this forum about wanting to install a 2nd hdd and gave a negative point to this laptop because you couldn't. Well actually you can. If you open up the laptop (you have to remove the keyboard etc) there is a space inside the laptop for a half slim ssd. Check the picture below (Now this picture is from a 3810. Now our laptop is pretty much the same inside just a few things different.)
In the middle right of the picture there is a space with nothing in it. To the right of the blue board. You can connect an SSD in to that space using the connection from the blue board and then you have a SSD and the original internal hdd in your laptop
(2 HDD's
) On our laptop the space is in the bottom right corner instead but same thing applies.
This is how it fits:
So if anyone wants a 2nd hdd there you go
INSTALLING A 3G MODEM
Also the laptop is ready for a 3g modem. It all ready has a sim card slot in the case. If you remove the battery and then look to the left of the battery connection on the laptop you will see a black sticker covering something. If you remove this black sticker it will reveal a fully functional sim card slot. You can insert a sim and remove. Now this doesnt give you 3g. All you need to add a 3g modem into the laptop is purchase a 3g wwan pcie card like this :
And plug it in to the slot in the top right (you can see the slot in the first picture I posted. Top right of picture). They cost ab
