Did you wipe dalvik cache and then wipe all user data in recovery before flashing?
I came from Cyanogen 6.1 so I factory reset and wiped cache, didn't wipe the dalvik cache though?
Wipe Dalvik to, it's always worth wiping every now and then, helps keeps things smooth.
Still getting crashes in random apps. Phone doesn't fully reboot though, I just get the Android loading screen and then it returns to the home screen with no widgets.
Could it be the Gingerbread theme I'm using?
can the camera app be modded at all in oxygen? Its a bit basic?
