- 1 Jun 2010
- Bedford
Pretty much, some of the numbers don't make sense.
So is the powertune overdrive enabled with catalyst 10.12? Sorry for my noobish ignorance
No currently released drivers support the 6900 series, I'm sure AMD will post a hotfix on Wednesday.
Then howcome benches have been conducted with the 6900 cards?![]()
That's why I wrote that the synthetic benches for the 6900's don't match reality of in-game performance. Perlin Noise was low precisely because the power limiter was in place. I bet if someone cranks it up 10% in power, scores shoot way up
The benchmarks where the 6970 is being compared against 580; is the 580 at stock speed? If the powertune is increased further by 10% on 6970, wouldn't the 580 still beat it if it was overclocked to max aswell?
The difference is that it seems like the 6970 would be set to advertised clock speed when the slider maxed (basically downclocked before that) which would be comparable to the 580 at stock speed aswell.
By default the 6970 would be clocked at 780Mhz core (if comparable to the 6950 slide) with a 880Mhz rated chip. Then past 880 could be considered overclocking.
This is exactly what I was thinking aswell. So when the powertune slider is maxed it will bring 6970 to the stock speed of 580. Afterwards it all depends on which card overclocks better thus retaining the lead.
.Well the exact speed of the 580 is not relevant to the 6970
IF the information leaked is true then yes we haven't see a 6900 run at its natural potential yet. It's been so up and down there is no point in getting too eager about this as it may still be false and might not deliver a game changing size increase if true.
Lets keep our feet on the ground![]()
