*** The Official HTC Desire (Bravo) Thread! ***
Grrr. Defrost has been becoming increasingly unstable for me. 90% of the time gmaps crashes during navigation.
Can you guys suggest to me a rom? Or should i just wipe clean ad reflash defrost.
Using clockwork mod, anything else i should be doing?
I was having issues with DF as well. Moved to Oxygen last week and been very impressed. Give that a go.
My install was a bit flaky first time round. However, the second time I did it I restored each app individually from Titty Backup and only restored app+data for essential apps, everything else I just restored the app. Previously I had done a batch restore. Been stable as a rock since then. Don't know how you restored apps after installing the rom, but might be worth giving it a go.
Does anyone know if there's a website that lists all the current up to date ROMs? Getting fed up with trawling XDA forums :p
I think Oxygen is my new rom of choice, now that they have fixed the media controls with the volume thats my biggest fault gone.
I cant go back to sense roms after using non sense ones for so long,they are just a lot more responsive for me.
Seeing they will be adding the controls to the notification is a good thing but i bought extended controls when i got my phone now thatll be put out of use
I've done a fresh install of the rom, and instead of doing a Titanium restore, I installed each one manually from my Appbrain list.
Seems more stable now, haven't had any crashes yet :) *fingers crossed*
Thanks
I did the same, although after using Cyanogenmod for a while which also has notification controls, I prefered it to extended controls. Saves screen space :)
How hard is it to install LeeDroid? I've already rooted my phone and my current phone I just downloaded it and loaded it using clockworkmod.
On LeeDroid Finally the battery charges to 100% and the LED goes green, instead of going green at 90% :D
Coolness!
After reading the last ~30 pages of the oxygen thread, it seems i'm not the only one getting random restarts during apps. It's the same symptoms for everyone else too.. phone freezes, and drops to the boot animation.
Hopefully it's something that will get fixed before the next update :/
I'm running a clean install of Oxygen since 1.0 and never had any of these problems? I've also updated using the Oxygen Updater. 1.0 > 1.0.2 > 1.0.3 no problems at all. :)
Might be worth trying a clean install maybe?
