No, it's fine. Enjoy your SSD.![]()
Start -> "disk defragmenter" -> Configure schedule -> Select disks...
start -> "cmd" -> "fsutil behavior query DisableDeleteNotify" (0 = TRIM, 1 = no TRIM)
I'm glad its you asking all these noob questions about the OCZ Vertex 2, as I'm just about to click buy on one and am pretty much in the same position as yourself, noobwise![]()
Well if it isn't in the list then I guess Windows 7 has removed it after detecting it's an SSD. So leave auto-defrag on for your D: drive and maybe check it after the first scheduled run to make sure your C: drive hasn't been defragmented.TRIM is on, nice one thanks.
When setting up schedule for defrag under select disks it says select all disks and data (d) hdd but I can't see my C drive in that section.
I have to select all disks otherwise it wont let me click apply. Is that right>
One other thing, in the power settings it says turn hard diks off after 20 mins if not used, I normally always set that to never, is that ok to do for SSD? I never have my PC go to sleep, hibernate etc...
RoEy
I'll post back here once I have it up and running mate. Hope yours turn up too!
RoEy
