yesthe official 10.12 on amd's site supports 6900? doesnt mention a thing
i did enable the unofficial overclocking in the config file.
but it keeps crashing anything over 860mhz~.
did u use the power control? or was that at 0%
I think the whole 2gb thing on the cards is done for 2 reasons:
1. To the average user, they will see 2gb on the AMD cards compared to 1.2 or 1.5 onthe Nvidia's and get a bit blinded by the marketing.
2. The 2gb of ram, really becomes apparent when crossfire vs sli is compared. No more memory bottle for the AMD cards.
I think its about time anyway, that video cards start having 2g of ram, might as well lift the memory bottle neck.
quick question by using the power control would it vold the warranty with ocuk?The way I did it was this:-
Open up overdrive, slide power control too +20 and fan too 65%
The open MSI after burner and push the clock speed and memory speed. Click apply, then set up a manual fan profile, click apply.
Then go back to overdrive you should now only have two sliders, power control and fan, set power control to +20, leave fan as is, press apply.
Now test for stability.
I will be amazed if you can't get past 900MHz, everyone I have used now which is 6 cards all hit over 900MHz using the above method.
However if your in Crossfire you can't overclock the second card, apart from only in overdrive, I just got blue screen of death even if I tried to downclock the second card which clearly means for crossfire OC support in MSI afterburner needs a patch/fix update.
i just tried 10.11 driver i can get to 910 without the power control
ohhh i really didn't know this, it's good to know, i think that's great that ocuk does this, thank u mate,No it won't void your warranty.
We allow our customers to overclock their cards as much as they wish, we are overclockers UK afterall.
The only way you will void your warranty is if you start removing the cooler or modifying the card in someway like soldering different resistors on it etc.
Any ArmA 2 benchmarks up yet? If any game will make the most of the extra video memory this game will.
Hi , do you get a 8pin to 6 pin converter with the his 6970 card from ocuk , i have seen a post on here where it shows 2 x 6pin to molex but on the web add it says a converter is included
The HIS cards come with two adaptors - one DOUBLE-MOLEX-6PIN and one DOBLE-MOLEX-8PIN
i have got mine to 915mhz on the core without using the power control. but there cards do not like heat!!!.
if i oc it to 915 it runs fine if the temp stays below 47c~ if it goes over 47c~ it crashs
nope shouldn't matter.I haven't tried to clock mine yet , does it matter which dvi port you use?
My 6970 giving me strange gfx rendering shapes in WoW Cataclysm even after changing drivers and my 5870 never did it so got no idea what else it could be.
Anyone else experienced this? other games seem fine so far but not tested much yet.
ATI Radeon 6950 in Crossfire @ 840MHz Core & 5300MHz Memory
