Well I got mine today (8371) and trying to put on the Windows XP using the discs that came from Acer. As you can probably tell bad move. Bad move indeed. It takes like an hour to install because it's a custom xp discs (2 dvds and 1 bootable cd) i.e. pre-installed OEM crap on it.
Point being that after waiting for all this to install (it does this automatically) and the drivers (does this automatically too) it failed to install both gpu drivers.
My question is this: how do I install the drivers in the proper way do I for example disable the gpu in the bios and install one at a time like that?
Have you guys updated the bios when you first got it - I have not yet only because I wanted so see if it was working etc first.
Thanks for any replies.
ps @AmDaMan bad luck there dude
