Driving impressions
Just thought I would give an update after a few days with the car.
Now there are a few bad points on the car I have discovered.
The electric aerial is not going up or down properly as discussed earlier.
If the aerial is dirty the headunit will give a headsup (clean aerial) so sounds like a problem else where, the whole unit can be picked up quite cheap on ebay and take minutes to change over
one of the 4 head light glasses has a crack in it.
Again £15-20 on the bay
There is a knocking from the suspension it sounds like it is coming from the back on the drivers side but I cant be sure. Its not bad but it is noticeable with the roads as they are at the moment.
Rear suspension knocking could be the normal bushes or ball joints however our suspension is well knock to trapping the old stone under the coil and creating a knocking noise, this is an easy fix when up in the air
last thing I have found is that only one of my remotes works and even that has to be very close to the car. I assume this is just 2 crap batteries.
This could be a problem, of course check the batterys first simple fix if this is the case, otherwise you have the same problem I had a year ago, unfortantly the damp gets into the remote central locking ECU and this has to be replaced and arent cheap, I luckly found one on ebay for £40
