Based on the results of their own review the HD6970 does "blow the GTX570 out of the water". Whether the review is correct or not depends on how the results can be interpreted. They are not wrong (as the FPS is literally what was achieved) but "could" be constructed in such a way to favour one card over the other. Unfortunately this is pure conjecture.
The point about the GTX580's is a perfectly valid one. For a site that is supposedly biased towards AMD doesn't it strike you as slightly odd that the owner runs two Nvidia cards? He would get the HD69xx free as well so why isn't he running them if they are so biased?
One quote on the site is not enough to start calling them biased especially when that quote is putting into words what the results showed.
Our concern was that AMD would shoot themselves in the foot by pricing the Radeon HD 6970 in particular at too high a price. If we take a straight average at 1920x1200 and 2560x1600, its performance is more or less equal to the GeForce GTX 570.
Anandtech
While the HD 6970 2GB is undoubtedly a good graphics card for around £300, unless you really want EyeFinity support, the GTX 570 is a better bet. The GTX 570 1.3GB handles AA significantly better in the majority of games, and for high-end graphics cards, this matters, and it's also cheaper.
Bit-tech
Unfortunately AMD's Radeon HD 6970 can not meet that price target. With performance comparable to GeForce GTX 570, but a price that is $50 higher it is difficult to justify the investment.
Techpowerup
The upshot of an experimental design and difficulties with ramping up speed on a 2.64bn-transistor die means that the Radeon HD 6970 is between 15-20 per cent faster than the Radeon HD 5870 card it effectively replaces in the AMD performance stack. Tellingly, it's about the same speed as a GeForce GTX 570 and, no matter which way you cut it, slower than a GTX 580.
Hex-s
Looking at it this way, the HD 6970 blows the GTX 570 out of the water for a few bucks.
OCP biased they be.
@ gerard, I thought the FT02 had decent cable management.
