***The Official Gran Turismo 5 Thread***
I just cant seem to catch up with #1, and its always the last lap close to the end where i get into second place.
Aerodynamics Downforce: 20
Transmission Max Speed: 211
LSD Initial Torque 5/13
Acceleration Sensitivity 21/45
Braking Sensitivity 12/20
Torque Distribution 35/65
Suspension;
Ride height -20/-20
Spring raare 15.5/10.9
(default rest)
Wheel Alignment;
Camber angle 2.2/1.5
Toe Angle 0.18/-0.10
break balance 6/5
^ probably all wrong, but i played about with several different settings and this was the one that got me the closest..
Yeah you are over thinking things - I didnt bother with an aero parts, it will just introduce drag (its not like the GT-R has issues with grip more about turning the bloody thing). Same with regards to suspension and LSD
Deffo get your max speed right down to 180 - that just about maxes out when you have a slipstream down the pit straight - you could go one higher but I wouldnt, the opportunity to go much faster than the 170ish it gives you is very low already...
Id default all the LSD and Suspension settings (except for ride height) just because I really dont have enough knowledge on how it really affects the GTR in GT5. Im one of those people that try the settings I understand how they will affect the car and only then fiddle with the rest (havent had to use any suspension mods yet)
Torque distribution seems fine if you like the rear not to slip too much and again if you are changing that its probably best to leave brake balance alone. Think I used 30:70 or a bit higher..
With regards to the track ensure you have got a great line sorted for the last corner for obvious reasons - what I do is brake in the chicane as I turn into the last corner but nowhere as much as GT5 thinks you should - with the braking for the previous corner (the one as dip into a small tunnel) you should be able to place your car so that you can straight line it into the chicane before braking for the last corner...
Also the 4 corners (first is a left/right then its a right/left) before the middle hairpin as that taken well is pretty much a straight with a lift off for the left/right and then a small amount of brake for the right/left.
Sorry that sounds a bit messy - hopefully you know what corners I mean - doing that and not overdriving the car (braking far too late so you lose traction out of a corner etc) its hard not to be able to pass the Ford GT at the hairpin or down the pit straight on the last lap...
ps3ud0 :cool:
Stupid question re RX-&s in the online dealership - theres a Bathurst R which the description says in RL it had hight adjustable suspension as standard. Am I expecting too much that the GT5 version when bought would have that option already fitted too as standard?
Otherwise I might aswell go for the premium Spirit R model
ps3ud0 :cool:
sydney in the middle of the tuning championship, 10-15 mins then ill send over the pain, remind me of ur in game name.. no need for anythin in return, i owe you for the car you gave me :)
oh, ok then, I suppose I did din't I!
Fish12002 is my PSN-ID
Bennah after 10 attempts at the Seasonal GTR race I couldnt get first place :( second was the best I could do, sad to see that 300k just sitting there... I will send your car back soon
No problem pal.
I didn't mess around the all the LSD and suspension, just added downforce to the front and rear. Helped a lot. Try shortening the gear ratio.
With the GTR I did it first time :)
You want an MR car? I have a Ferrari Scuderia that could be a little use. Not sure I need it for any forthcoming races. I'll check in the morning.
yeah its pretty lame, dont worry ill just need to buy one :P almost finished expert, did you get the paint?
oops, sorry mate, doing some online racing atm.
As for lending out a gallardo, I've offered one to someone who just got the game today, otherwise, I could easy buy another :p
Hint: B-Spec America Cup Extreme race thingy, Indy Oval, 100k per win
if someone gets a chance can they tell me the best settings to use on the Mustang V8 seasonal bonus race 2?
I CANNOT get this mother to turn, 1600KG of immovable metal
I put 4 degrees of negative camber on the front suspension, which is an insane amount, and while it improved the car, its still difficult, I'm finishing about 2 seconds behind atm, and can't seem to improve because I can't seem to string a decent set of laps together :(
Got this for Christmas. Loving it!
Stuck on one of the B licences atm though. It's the one where you need to navigate a hairpin in a Meganne in 15.6s or something. I've done it in 15.641... GAAAAAAY
