What's the best way to create a railway system that simply goes from A to B then stops, then you can go from B to A?
there server runs this mod
http://www.minecraftwiki.net/wiki/Minecart_Mania!
So obsidian block at each end with some gold blocks as boosters I'd imagine
if the chat commands work.
has it crashed?
Just as I fell into the hole with the spider spawn, was a chest in the room as I went down.
if the chat commands work you wouldnt need the gold blocks to boost, you could just use '/throttle x%' whilst sitting in the cart. it does feel a bit like cheating considering the work put in to the new server, though.
Ideally we'd be able to change those gold blocks for something a little more readily available, then carts and tracks could really take off.
has it crashed?
you can use just gold ore.
Elevator Signs
A sign with the text "Elevator" (case-insensitive) on it at a particular spot, and a similar sign with matching text somewhere on the same Y plane (above or below it) with track leading to one sign, and away from the other, will cause minecarts to be transported from one sign to the other, seamlessly without the loss of motion.
