OcUK wouldn't cheap out on the paste. It wouldn't make sense for them to do it.
Most likely is it got moved in transport.
Attaching a heatsink as you've found out isn't incredibly difficult. 60 isn't a good idle temp though it isn't a terrible one.
What is important is if the machine is stable, and if it's a decent load temperature, idle temp is just a vague indication.
You should speak to OcUK support and ask them what to do. In my opinion it's fine for you to use the PC for now.
