Minecraft OCuK Forum Members Server Thread
im in for the night too, been busy digging our end of the underground, goes from my gaff, next to aypez's and along maybe 600-800 blocks to tefals fort :P 3x3 yo!
I have an idea I'll have to dig a large bit of my tunnel again due to the crash.
There surely can't be issues about space the map is huge no??
Just saw this awesome quote on the minecraft forums:
"Creepers are female? That explains why they seem to explode at you for no reason, even if you've done nothing wrong."
on a side note any ideas as to why we can't login?
I only have one thing to add about the railway.
Railways should run on flat ground they should not go up or down more then 1 block for every 50 blocks, thats 50/1.
This means when laying the tracks if you come to any of the below this is what you do.
Hill = Cutting
Mountain = tunnel
Valley = bridge or embankment
Sea = bridge or tunnel <<< 1 block drop for every 50 blocks
Fenced & torches to make monster safe.
Your house should go to the railway not the railway to you house, so if you have built your house on a hill then you make a path down to the station.
Now next subject items been taken from your chests.
I will not be spending the very little time I have chasing up bbhere reports looking into such things when I have given you the option to have a vault.
I know that /bbhere is not working 100% player side I am working on getting it fixed with the host.
I will look up the bbhere reports if someone has there work destoryed.
I will not give other users details to restart the server as if it's not done in the right order & just done the quick easy way you could end up with a roll back.
I have just got in from work this is why it's only been restarted, I think the host may have stopped it from working while looking into the bbhere problem.
As the server logs do not show a server crash.
