Old school but off the installation CD provided with the unit?
Don't recall one, I've got documentation CD but that's it. Will check if it is on there tho.
This is the link from HP's site which then links to AMD directly for the "AMD SB7xx/SB8xx Chipset Windows Server 2008" drivers. For me tho the AMD site is timing outDon't recall one, I've got documentation CD but that's it. Will check if it is on there tho.
http://h20000.www2.hp.com/bizsuppor...wEnvOID=4064&swLang=8&taskId=135&mode=4&idx=0
At the moment mine is stuck in a boot loop and I'm trying to repair it.
Yeah that's what I meanAt the moment mine is stuck in a boot loop and I'm trying to repair it.
Hoping some kind soul can either upload the driver or has an alternative link for it![]()
Try this, this is the SB8xx folder from within the 13xmb AMD zip. It's the only folder that mentions RAID.
http://www.mediafire.com/?v5aydxv5t6llnas
On another note how to I enter the bios? I'm trying to set WOL as that would be fairly handy. I've tried the usual keys but nothing seems to work!
I'd say it was a MFT/GPT issue but normally (in Windows) this would limit you to 2TB per partition, rather than 1.2TB.
What does it look like in gparted (think ubuntu renames it Partition Editor in the menus)
I already did...I'm not using the ODD sata port I've got the 160 GB drive in Bay 1 and two 2tb's in bays 3 and 4, the 2tb's are in raid 1.
Any luck?
I'll upload the full zip file, 2mb upload so shouldn't be longIt's the right driver, but to install the .msi file I need catalyst install manager which I also can't find.
Thanks very much though![]()
No probsThanks man! Sorted nowcheers.
I haven't heard back from the claim form I posted so have scanned it in and emailed it together with my invoice to [email protected].
On to your second question: you do realize that the RAID is fakeRAID and that the drivers are Windows only (not sure if there Red Hat ones actually since Red Hat is officially supported by the Microserver, but there certainly is no Debian support).
For Linux you have to use Linux software RAID - performance should be about the same since the fakeRAID uses the CPU anyhow.
