- 17 Aug 2003
- Woburn Sand Dunes
excellent work so far guys, well done
im right next to tostring on the map, for the railway system...
This was discussed earlier, I don't really understand why garsands wants this. We've already broken the rule in quite a few places. The majority of track will be straight and a few blocks deep , it's hardly any effort at all to connect tunnels up. My only reason for -11 was to ensure you are under sealevel, but those who were doing the line from spawn to east station had to go a bit deeper because of falling sand/gravel.
garsands also mentioned he wanted a lot of it above ground... if this is to be used as a transport system, underground is much much safer, providing that it is sufficiently lit.
Would it not be better to do it the hard way so it takes longer why the big rush to put it up quickly.
Hello My Name is Dominic Goodchild Friend of Damiens can i be Added to the White List username is Dmoe18 Thanks
Because running 600 blocks to get to places gets old fast.
Unfortunately if your station is closer to spawn/yellow line than a substation... it's a bit of tough luck.
If we start connecting directly to lines we shouldn't, it becomes a big hoo-haa...
