iCook: 'Beer-in-the-butt' chicken with Parmentier potatoes
Caporegime
13 May 2003
Warwickshire
Basically: get a beer can, drink half, cut the top off with a tin opener, stick it in a chicken, roast chicken!
The beer steams the inside and keeps it moist whilst cooking, also imparting a great flavour.
Tl;dr pic:
:D.
Recipe:
- Get a reasonable chicken, I used an £8 free range corn fed from Tesco. Season its skin with sea salt, then stick it in the fridge over night with its skin exposed.
- Drink a can of lager or something, open its top up with a can opener, then fill it halfway with your cooking beer of choice. Halfway because otherwise it just spills over into the tray. I used a local ale, (Purity Pure UBU).
- Put some rosemary, garlic, and lemon into the can also. You can alternatively use any chicken-friendly herb that you fancy...tarragon, sage, thyme...
- Create a rub for the chicken. I used extra virgin olive oil, a chicken stock cube, some chopped rosemary, and salt. Rub it all over the chicken.
- Slide the chicken onto the can.
- Stick a whole pealed onion in the neck, both for flavour and to try and trap some of the steam from the beer:
- Put the chicken into a hot oven (230 deg C fan!). It needs to be this hot if you want a very crispy skin.
- Meanwhile, for the parmentier potatoes (or a variation thereof), cube some Maris Pipers.
- Fry in plenty of butter with chopped garlic for five minutes, just to melt the butter and coat the potatoes.
- Set aside. Fry a couple of shallots and some streaky bacon, then add back to the potatoes. I also added some chopped rosemary. To finish, they need ~15 mins at the top of a 200 degree oven (fan). Alternatively, allow to cool and put the batch in the freezer for later, as I did with the unused potatoes (I prepared an entire bag of Maris Pipers).
Meat thermometer tells me it's done!
Rest...
...and make up a gravy from the chicken bits from the baking tray and the onion from the chicken neck, using white whine and a roux to thicken if necessary.
Served with some steamed broccoli:
The humble chicken...crispy skin and super-moist meat, vastly underrated in restaurants across the land!
What a nice idea! I'm going to say that I'll try this, and even though I intend to I probably won't get around to it ever, but I certainly enjoyed reading about it and looking at the tasty pics.
As an aside, how does the meat thermometer work as far as telling you the chicken is cooked?
Looks delicious and a pretty innovative method of using the onion to preserve steam and create the gravy. :D
looks delish! I will defo try this however wont be using that French Rubbish :p Does Peroni come in can form yet?
I'v done this before.
I used a full can and just used the extra that spilled over in the gravy.
I forget the actual temperatures but when meat reaches somewhere around 72 Celsius it's officially 'cooked' by health and safety standards - probably something along those lines :)
Ok, and how do you know you've got the temperature of the coolest part of the meat? For example you could be reading 72 but there could be a part still at 60?
I only used the 1664 can as a vessel ;).
It has both a temperature scale and a list of types of meats...the arrow rotates and when it lines up, it's ready. With chicken, I usually aim for the pork setting, firstly because chicken overcooks very easily, and secondly, it keeps cooking for a while afterwards while it's resting.
I am impressed but why am I not surprised about you inserting objects up a chickens arse?
Also did anyone else think of the chicken scene from Withnail and I?
Looks good. I've got a huge scar on my stomach from cooking chicken like that. We cooked it on the barbecue exactly the same as you did. However, when I moved the chicken, the beer boiled up and sprayed out violently all over me, burning me badly on the stomach. So watch out folks :D
It'd be quite interesting to hear about some of the other scars you've managed to acquire over the years, some of the stuff you do literally bends the mind!
Sat up like that would you need a gas/proper fan oven rather than conventional to cook it properly?
What kind of flavour does the beer give chicken or is it more for moistness? Bit of a new one on me that.
Nice. Tried this once without the spices etc and cider, need to try with beer or ale.
Tip: if you like crispy skin, pour hot water over the bird and wipe dry then add the rub over. Works well for turkey also.
I do this every BBQ season, it's bloody lovely :D
Except I just stick some chopped onion in the can and around the insides of the chicken, and my rub is:
Paprika
Cajun spice
Rosemary
Pepper
and lots of ground sea salt to dry up the skin and make it go crispy :)
Here's some pics from a 2010 BBQ. It's only a small chicken so i could fit it in the BBQ along with the beer-can and still have the lid closed!
