If you are looking at LCI E60s primarily, don't rule out the 525d, it's still a 3-litre 6-pot with ~200BHP.
Yes, my brother in law has one, and by my failure to keep up with him the other night in my e39 528i, I rate the diesels performance !!
They're pretty much the same as far as I know.So the 525d has the running costs of a 3 litre but with the benefit of slightly lower tax?
[TW]Fox;18147888 said:I take it that the 528i is not in the best of health then?
, then again, it hardly surprises me that such a car would walk all over my example - in terms of performance. Does it you?
Perhaps when it came out of the factory 15 years ago[TW]Fox;18151620 said:Yes, it does, as the performance in each is roughly the same.
Perhaps when it came out of the factory 15 years ago![]()
See how it dyno's @ 263 (ish) k
[TW]Fox;18151968 said:You can, as you'll probably own it by then![]()
They all come with nav, surely, but just the 4:3?no nav, which is weird as he chose the logic7 sound package!
you can get a much nicer sport for the same cash, just shop around
Dealers can be lazy and don't often list the full spec, esp. when it's standard equipment.One of them doesn't say it has leather, but it does?
FWIW, the Logic 7 is well worth it IMO and not a particularly commonly-found option.
