 - 27 Dec 2005
 - Bristol
Anyone have problems with WidgetLocker and alarms not sounding fully/not getting dismissed properly?
is stock quote the best stock app out there?
Try opening your alarms, go to edit one, go to edit the tone and then turn up the volume using the hardware controls. Make sure you do this while the window for selecting a tone is open. My wife turned hers down by mistake before.Is there a good App for Alarms? The alarm on my Samsung Apollo rarely goes off. I'm not sure if it's a problem with the phone or not. I just set it a moment ago for 21:50pm, when it got to 21:49pm, the phone lit up and the time jumped to 21:51pm. :/
	Tunein radio is a great little internet radio app. Very smooth and loads of stations plus it's free!
Stop it!! I've got far too many apps installed as it is!! Tunein is rather good though![]()
 Tell me about it, I've only got 15mb free on my desire and everything that can be on the SD card is.Time to upgrade!I'm listing to prior get his century right now on itTell me about it, I've only got 15mb free on my desire and everything that can be on the SD card is.
	I used to use colornote but I find Mobisle Notes much more capable, there's a paid version which integrates with google docs but it's too expensive imo.
Also the backup feature in colornote does not work between devices... Or at least it didn't for me.
Have you checked your alarm volume as per my post above?Can someone suggest a good Alarm app, as my built in one on my Hero did not work this morning for some strange reason.
