- 28 Dec 2008
got a few 3810s here....
Help .. updated BIOS to 1.28 (from Acer) but fan is always on .. is there a better version for the 3810TG ?
Thanks
John
You sure the slot isnt hiding behind a small bit of black tape?If anyone know how to fit the SIM with this non-SIM friendly model then please let me know as most forums add the WWAN card to the machine with some slit behind the battery which is already connected internally to the WWAN connector.
INSTALLING A 3G MODEM
Also the laptop is ready for a 3g modem. It all ready has a sim card slot in the case. If you remove the battery and then look to the left of the battery connection on the laptop you will see a black sticker covering something. If you remove this black sticker it will reveal a fully functional sim card slot. You can insert a sim and remove. Now this doesnt give you 3g. All you need to add a 3g modem into the laptop is purchase a 3g wwan pcie card like this :
And plug it in to the slot in the top right (you can see the slot in the first picture I posted. Top right of picture). They cost ab
Wahey .. I must be blind but that black sticker is VERY VERY difficult to see but I found it and indeed the slot is thereSO I am just waiting for the WWAN from China. THANKS !!!!!!
Installed the new BIOS and it seems OK.
I Think £398 is the cheapest - it has gone up from £389 that I paid with VAT increase![]()
Can someone ping me a trust on best price on the 3810TG please?
Ta
EDIT: Found the LX.PE702.016 for £398.29 that sound good?
Good question .. I have an old antenna (says Apple) which I added and then removed from my UL30 .. that might work or will wait to see what comes with the WWAN card.
