What is the major point of SSD?
Fast. Rapid. Presto. Speedy. Speedball. Nimble. Agile. Brisk. Electric. Swift. Quick. Like a bat out of hell....
If you want to be pedantic then maybe substitute better reliability for better durability.So you're placing better reliability in the same list as limited write cycles eh? Yes, that makes perfect sense.
As there are no moving parts then you could drop a laptop with an SSD in and you would not lose your data. Try it with a laptop with a mechanical HDD and you probably will...
Once you go SSD you wont go back, only someone who's used one will know everyone else just thinks they're expensive
MW
not if you bung the hdd in the freezer![]()
Main issue for me is the price and size:storage ratio (i.e. space they take up in your case while offering only limited storage capacity). I'd have to remove a 300GB drive to fit one, which wouldn't be the end of the world (would be nice to retire my IDE drive) but it would just feel inefficient replacing it with something smaller capacity wise.
