[TW]Fox;18159032 said:And I say that not as somebody who is holier than thou, but as somebody who knows very well what happens when your driving sucks.
Citation please
Citation please![]()
[TW]Fox;18159075 said:I once had this BMW which I thought I was amazing at driving. Turns out actually I was just as average as everyone else when it comes to car control![]()
I'm not saying it was necessarily the case here but I am amazed at the tiny gaps people leave between them and the car in front. In fact I would go as far as saying what most drivers consider a safe distance at 70mph even when prompted is laughably too close should the car in front have to make an emergency stop.
Would a 330 not have gone into the back of the Insignia then?
Given how comprehensively the lighter 316 Compact went into the Insignia, I rather doubt the results would have been very different in a heavier 330, wider tyres or not! Still, a bad workman will blame his toolsNo offence, Tom!
I guess most people have read the Highway Code better than you
The HC advocates leaving a 2 second gap on faster roads such as motorways (double this in the wet) which is not enough to avoid a collision if the car front went from 70mph to stationary instantly. The point is that this is most unlikely to happen (impossible in fact) - 2 seconds is enough to absorb your reaction time and the difference in speeds if the car in front starts braking hard.
If a stationary object suddenly appears in front of you, then the gap you have left to the car in front is irrelevant...
126
Stopping Distances
Drive at a speed that will allow you to stop well within the distance you can see to be clear. You should
leave enough space between you and the vehicle in front so that you can pull up safely if it suddenly slows down or stops. The safe rule is never to get closer than the overall stopping distance (see Typical Stopping Distances PDF below)
allow at least a two-second gap between you and the vehicle in front on roads carrying faster-moving traffic and in tunnels where visibility is reduced. The gap should be at least doubled on wet roads and increased still further on icy roads
remember, large vehicles and motorcycles need a greater distance to stop. If driving a large vehicle in a tunnel, you should allow a four-second gap between you and the vehicle in front
If you have to stop in a tunnel, leave at least a 5-metre gap between you and the vehicle in front.
you quite clearly don't read the highway code, because it advocates At Least a 2second gap
Or more Specifically:
http://www.direct.gov.uk/en/TravelAndTransport/Highwaycode/DG_070304
It quite clearly says "The safe rule is never to get closer than the overall stopping distance"
The Overall Stopping Distance at 70mph is ..315 feet / 96maccording to the highway code.
http://www.direct.gov.uk/prod_consu...n/@motor/documents/digitalasset/dg_188029.pdf
Thats quite long, which i dont think anybody on the motorway follows so this isn't a criticism of Tom.
Considering a car with Good Brakes like the 330i can stop from 70 in under 200 feet, thats plenty of room spare to panic and still stop in time.
The highway code does not advocate leaving a stopping distance which isnt long enough to stop safely in the event that something like this happens (ie the car in front impacts something and comes to an abrubt stop)
I would imagine probably what is quite dangerous these days is actually the variation in vehicle abilities that are on our roads.
If you're in a 20 year old Ford or Vauxhall without ABS behind a new Merc that does an emergency stop, I'd hazard a guess that even following the two second rule would see you plough in to the back of them.![]()
Also when I'm in a stationary/10MPH queue you see people pull out all the time into the middle lane without a care in the world, not so funny when the HGVs have to slam their anchors on!
