What Is Twice As Cold As 0°C?
But the question is asking about differences in quantities which are dependant on scale.
but there is a definite end to the scale, it's like asking what's half the height of a 10m tower, the answer can be in feet meters etc it's the same.
0 C is not 0 in terms of temperature it's actually + 273 C
In one of those 4am thoughts a few years ago, I remember thinking how darkness and cold don't exist, they're just lower values of light and warmth.
Sort of, not really. light and heat are measurable manifestations of energy, darkness and cold are perception constructs created by the brain.
_________
Isn't there also that thing where if you poor cold water over one hand and warm water over the other the brain cant tell which is which.
you can get warmth from 0c therefore it is not 'cold'
but assuming by 'twice as cold' you mean half the temperature then you do it by converting like people have shown.
+273 kelvin surely? :|
-8.88888889 C after some googling :D
0c=32f
32f/2=16f
16f=(see above)
Only if you've been turned into a cherry flavoured popsicle by some unfortunate industrial accident. Warm and cold are relative to the measure.
warm and cold are not relative in physics. 0c is never 'cold'
'cold' is absolute zero but i dont think you would find many physicists describing something like this as 'colder' , 'warmer' etc. i would assume it would be 'lower temperature' 'higher temperature'
i have a question, how do you know a lot of people that do this? are you a scientist or something? if so, why don't you just ask them about it :p
0 is just a point on a scale, nothing more. Why are you assigning the meaning of absolute zero to it?
because the op is asking whats half the temperature of 0c ?
if hes really asking 'twice as cold' then he needs to ask again because its not worded correctly
eg.
"Cold" is confusing in the same way that "short" or "small" is
confusing. If I say that I am twice as short as you, what I probably
mean is that I am half as tall as you. It isn't really a good way to
talk at all; it's best to say "half as tall" because it's less
confusing.
"Cold" is even more confusing than "short" because temperatures can be
negative, but height can never be negative (not the height of a
person, anyway). If "twice as cold" means "half the temperature"
